Synchronizing Site Updates from Third-party System
If you maintain and update site structures in another vendor, you can use NetBrain APIs to make the same site updates in NetBrain, such as adding sites and removing devices from a site.
Use Case 1: Replace Devices in a Site
Workflow
The pseudo-code below describes the main flow in the API script to replace devices in a site.
1. Login to NetBrain API server and get session
2. Set current domain
3. Replace devices to existing site
4. Call Commit to commit the change
5. Call GetSiteTree to confirm that all sites are created and devices are set
6. Logout NetBrain API server
API Script
You can refer to the script below to call relative APIs. This sample script first imports a python library maintained by NetBrain and you need to write your own one in practical use.
import netbrain_restful_lib
import time
import urllib3
urllib3.disable_warnings(urllib3.exceptions.InsecureRequestWarning)
user = "NetBrain"
pwd = "Netbrain"
nb_url = "http(s)://<IP address of NetBrain Web Server>/"
headers = {'Content-Type''application/json''Accept''application/json'}
tenantName = "Initial Tenant"
domainName = "Use Case"
# Step 1: Login to NetBrain API server and get session
print("Step 1")
token = netbrain_restful_lib.loginSession(nb_url, user, pwd)
print("Token: "+token)
print(netbrain_restful_lib.getTenants(nb_url, token))
print(netbrain_restful_lib.getDomains(nb_url, token))
#Sample results
# token : adf5b560-8e9c-4114-87bb-2eed24f0faff
# tenantList : [{'tenantId': 'a50af282-fa02-012f-a7f7-e410cc7c29d3', 'tenantName': 'Initial Tenant'}]
# domainList : [{'domainName': 'UseCase', 'domainId': '4f747a8b-71da-404b-a05c-e8505aa14725'}]
tenantId = 'fcf8a380-6b11-0fed-1d51-3b4cdef8f238'
domainId = '25b66365-1ab8-4fed-90c9-1307a4047c3d'
# Step 2: Set current domain
print("Step 2")
print(netbrain_restful_lib.loginDomain(nb_url, token, tenantId, domainId))
# Sample results
# loginDomain: Login successfully!
# Step 3: Replace devices to existing site
print("Step 3")
data=[{"sitePath":"My Network/US/CA/San Diego""devices":["BSTX"]} ]
print(netbrain_restful_lib.createSiteTransaction(nb_url, token))
for i in data:
    print(i['sitePath'])
    print(i["devices"])
    print(netbrain_restful_lib.replaceSiteDevice(nb_url, token, None, i['sitePath'], i["devices"]))
# Sample results
# CreateSiteTransaction: Site transaction created!
# ReplaceSiteDevice: Device moved successfully!
# Step 4: Call Commit to commit the change
print("Step 4")
print(netbrain_restful_lib.commitSiteTransaction(nb_url, token))
# Sample results
# CommitSiteTransaction: Site commit True
# Step 5: Call GetSiteTree to confirm that all sites are created and devices are set
print("Step 5")
print(netbrain_restful_lib.getChildSites(nb_url, token, None"My Network"))
for i in data:
    print(netbrain_restful_lib.getSiteInfo(nb_url, token, None, i['sitePath']))
    print(netbrain_restful_lib.getSiteDevice(nb_url, token, None, i['sitePath']))
# Sample results
# GetChildSites: [{'siteId': 'aac212cb-fa84-4ddd-8c0b-18a00ec9c323', 'isContainer': False, 'siteType': 2, 'sitePath': 'My Network/NA/US/MA'}, {'siteId': '3ebb978f-323a-4308-8b38-82fa1a0a135f', 'isContainer': False, 'siteType': 2, 'sitePath': 'My Network/NA/US/CA'}]
# GetSiteInfo: {'isContainer': True, 'siteId': 'ede2ed2b-d5cf-48dd-b341-020330757033', 'sitePath': 'My Network/NA/US', 'siteType': 1}
# GetSiteDevice: [{'mgmtIP': '172.16.8.186', 'id': '06840b62-8a67-4cb2-9ed4-e540ea36fdcf', 'hostname': 'NBUSMA-SW7'}, {'mgmtIP': '172.16.8.194', 'id': '0b152c13-34e0-474e-aa4c-b07fe71cc0b7', 'hostname': 'NBUSMA-R1'}]
# Step 6: Logout Netbrain API server
print("Step 6")
print(netbrain_restful_lib.logoutSession(nb_url, token))
Use Case 2: Remove Devices from a Site
Workflow
The pseudo-code below describes the main flow in the API script to remove devices from a site.
3. Remove device from leaf site
API Script
import time
import urllib3
user = "NetBrain"
pwd = "Netbrain"
print("Step 1")
#Sample results
print("Step 2")
# Sample results
# Step 3: Remove device from leaf site
print("Step 3")
for i in data:
    print(i["devices"])
    print(netbrain_restful_lib.deleteSiteDevice(nb_url, token, None, i['sitePath'], i["devices"]))
# Sample results
# DeleteSiteDevice: Device removed successfully!
print("Step 4")
# Sample results
print("Step 5")
for i in data:
# Sample results
print("Step 6")
Use Case 3: Delete a Site
Workflow
The pseudo-code below describes the main flow in the API script to delete a site.
3. Delete site
API Script
import time
import urllib3
user = "NetBrain"
pwd = "Netbrain"
print("Step 1")
#Sample results
print("Step 2")
# Sample results
# Step 3: Delete Site
print("Step 3")
data=[{"sitePath":"My Network/US/CA/Palo Alto"} ]
for i in data:
    print(netbrain_restful_lib.deleteSite(nb_url, token, i['sitePath']))
# Sample results
# DeleteSite: Deleted successfully!
print("Step 4")
# Sample results
print("Step 5")
for i in data:
# Sample results
print("Step 6")
