Besides the data from the live network, the system provides a framework to retrieve the data from third-party API systems via APIs and display the data on maps.
To help you fully understand the framework, a use case related to ServiceNow integration is introduced in this section. In this case, the system will retrieve the incidents information for all devices included on a map from ServiceNow, highlight devices with incidents, and then display the detail incident tables on the map.
