1.Enter any of the following keywords in the search bar:
Data Source |
Sample Keyword |
Site name |
Boston |
Device hostname in the site |
Gw2Lab |
Text in the site description |
Boston branch |
2.Click the
icon or press the Enter key on your keyboard to start searching. The search results will be displayed in the lower pane with the matched keyword highlighted.
3.Point to the target site entry and then click the
icon. Select one of following operations based on your needs:
▪Open the site map.
▪Draw site devices on a map (for leaf site only).
▪Draw the site icon on a map.
▪Locate the site in the Site pane.
Tip: In the search results, click the directory hyperlink of the target site to go for semantic search results. See Semantic Search for more details.
▪Site
