1.Enter any of the following keywords in the search bar:
Data Source |
Sample Keyword |
Path name |
Slow application path |
Destination IP address/hostname |
172.24.10.1/GW2Lab |
Source IP address/hostname |
172.24.10.34/BJ_core_3500 |
Note: If a path is calculated with IP addresses, it cannot be searched out by hostname keyword, and vice versa.
2.Click the
icon or press the Enter key on your keyboard to start searching. The search results will be displayed with the matched keyword highlighted.
3.Point to the target path entry and then click Map to diagram it. You can also click the path name to view more history records in detail.
Note: The Map button is only available if the path is successfully calculated.
