Note: The system built-in device groups cannot be searched.
1.Enter any of the following keywords in the search bar:
Data Source |
Sample Keyword |
Device group name |
BJ devices |
Device hostname in the device group |
GW2Lab |
Text in the device group description |
Troubleshooting |
2.Click the
icon or press the Enter key on your keyboard to start searching. The search results will be displayed in the lower pane with the matched keyword highlighted.
3.Point to the target device group entry and then click the
icon. Select one of the following operations based on your needs.
▪Open the device group map.
▪Draw devices in the device group on a map.
▪Draw the icon of the device group on a map.
Tip: To view member devices in the Device Group pane, click the device group name to locate it.
