The Qapp description refers to a summary of the basic information of a Qapp, including the following:
▪Description — the description of this Qapp.
▪Keyword — the keywords of this Qapp.
▪Author — the author of this Qapp.
▪Contact Info — the contact information of the author.
▪Sample Picture — a sample map or picture to demonstrate the analysis result of this Qapp.
1.In the Qapp Editor, click the
icon on the Execution Flow tab. The Qapp description is displayed in the bottom pane.
2.Enter the required information in each field.
1)Enter a description to describe the Qapp in the Description field.
2)Enter a keyword in the Keyword field as a hint.
3)Enter the contact information in the Contact Info field.
3.In the Sample Picture field, click Import to select a sample map or a picture from your local folder to visually describe the Qapp.
