Appendix 3: Python scripting
Python is a widely used general-purpose, high-level programming language with design philosophy emphasizing code readability. It has efficient high-level data structures and a simple but effective approach to object-oriented programming. Its syntax allows programmers to express concepts in fewer lines of code. Python knowledge is a plus when you create a Qapp with advanced outputs.
This appendix covers the following topics to briefly introduce the Python Scripting:
Basic knowledge of Python scripts
If conditions
Basic regular expressions
Installing Python
The system supports Python version 3.1x or higher versions.
1.Click https://www.python.org/download/releases/3.1.4/ to access the download page.
2.Download the Windows x86 MSI Installer (3.1.4) package and run the installer.
3.Restart your machine.
Qapp APIs
