Platform Management includes the management of data models, views and visual spaces for technologies applied to a tenant.
On the Technology tab, you can add a new technology and define the method of building data structure for the technology in the system. The definition includes the methods of discovery, benchmark, building topology and common API Interfaces for a network. The data and network model of the technology is defined through scripts in TechSpec.
Visual Space defines the properties in a data model that will be used as node and port, as well as the link (topology) for the nodes and ports. With these three basic objects, a network can be visualized on a map.
On the Visual Space Template tab, you can define different visual spaces for a view of a technology.
Tip: If you need NetBrain experts to help you add a technology, or customize views and visual spaces, you can contact NetBrain Support Team.
