As soon as a device group is created, the corresponding device group map is generated and named with the device group name.
1.Click the start menu
and select Device Group.
Tip: You can also double-click a device group icon on a map to open the device group map.
2.In the Device Group pane, expand the device group tree and right-click the target device group to select Open Device Group Map. A map page opens and all devices in the device group are displayed on the map.
Tip: For the maps of public device groups and personal device groups, the device group creator owns the map editing rights by default; for the maps of system device groups, the user who firstly opens the map owns the editing rights. See Map Editing Rights for more details.
