1.Click the
icon from the taskbar and select New Qapp from the drop-down menu.
2.On the Execution Flow tab, click Start to define device inputs. In this example, check the Map option. It means that the Qapp takes all devices visible on the map as device input and runs independently on each device.
3.Double-click the Canvas node to enter Canvas editor.
