The map data migration from Enterprise Edition currently supports the following objects displayed on map:
▪Devices, MPLS clouds, sites and device groups
▪Topology links and media
▪Device notes and map notes
▪Data units and highlight effects
▪Paths and shapes
▪Monitor results and legends
And the following elements contained in map files:
▪Map names, map pages, and thumbnails
▪Map zoom ratio and locking status
▪Device icon size
The following table lists the map objects that are displayed in the Integrated Edition with a different way from Enterprise Edition, or not supported in the Integrated Edition.
Map Object |
Supported in Enterprise Edition |
Supported in Integrated Edition |
Display in Enterprise Edition |
Display in Integrated Edition |
Map notes |
Yes |
Yes |
Interface names and IP addresses in data units |
Yes |
Yes |
Highlight effects of layer 2 ports |
Yes |
Yes |
Alert or change count displayed on device icons |
Yes |
No |
Effects of validating a map |
Yes |
No |
