Mapping a Historical Path
To map a path with the latest calculation result, do the following:
1.Click Path Browser on the taskbar.
2.Drag a path entry to the desktop area or to the current map.
Tip: To map a path with historical calculation results, click the hyperlink of numbers in the History column, and select an entry according to start time of calculation and then click Map the Path.
Tip: To re-calculate the path instantly, you can select the path on the map, click Add to Path Calculation Bar to add the source and destination IP addresses to the path calculation bar.
