1.On a map page, select Map > Map Tools on the map toolbar to open the toolbox.
2.Click the
icon to open the Map Stencil pane. It has two types of map stencils:
▪Shape — a variety of geometries including tables.
▪Device — device icons for each device type.
3.Select a shape and draw it on the map, or drag a device icon to your map.
4.Adjust the map stencil.
▪For shapes, you can click to change its size or double-click it to input texts.
▪For device icons, point to the device type (for example, Cisco Router0) and then click the
icon to edit the device name.
