Featured Management Privileges
When creating a user account, you can authorize the featured management modules to this user by selecting System Management, or User Management, or both.
The detailed difference between the two options is described in the following table:
Management Category
Featured Management Module
System Management
User Management
System Management Page
System Home Page, including Usage Report
User Accounts
Tenant Manager
License
Email Settings
Task Manager
API Plugin Manager
Front Server Controller Manager
Advanced Settings - Global Session Timeout
Advanced Settings - Audit Log + Login Logo
Resource Upgrade
Tenant Management Page
User Authorization
Domain List
MVS Configuration
Misc Configuration
GDR Data Configuration
API Manager
Interface Type
Platform Management
