1.Obtain the netbrain-frontserver-windows-x86_64-7.1a.zip file from NetBrain and save it in your local folder.
2.Extract installation files from the netbrain-frontserver-windows-x86_64-7.1a.zip file.
3.Right-click the netbrain-frontserver-windows-x86_64-7.1a.exe file, and then select Run as administrator to start the Installation Wizard.
2)On the System Configuration page, review the system configuration summary and click Next.
3)On the License Agreement page, read the license agreements and click I AGREE.
4)On the Destination Location page, click Next to install the Front Server under the default directory C:\Program Files\NetBrain\. If you want to install it under another location, click Change.
5)Review the summary of the current installation settings and click Install.
4.Click Finish to complete the installation process and exit the Installation Wizard. Close the pop-up registration program.
Note: The Front Server service will not be automatically started until it is successfully registered. You cannot register a Front Server immediately until adding the Front Server to a Tenant.
5.To install more Front Servers for load balancing, repeat the above installation steps on separate machines.
Tip: The installation log file is saved under the C:\ drive. If you encounter any issues during the installation, check the log file for more details.
▪Adding a Front Server Group for Load Balancing
▪Registering NetBrain Front Server on Windows
