Get the gateway information of a device
This function returns the gateway information of a device based on IP or hostname.
Resource Information
Method
URL
Required authentication
GET
/V1/CMDB/Path/Gateways
Yes
Parameters
Name
Description
Token*required
(header)
The token can be obtained by sending a POST request to the log in session endpoint and provide valid credentials.
ipOrHost*required
(query)
The IP or hostname of a device.
Response
Parameter
Type
Description
Example
gatewayList
array
A list of returned gateway devices. The list contains the following subparameters:
ip (string): the IP address of a gateway.
devName (string): the hostname of a gateway.
intfName (string): the name of the gateway interface.
  "statusCode"790200,
  "statusDescription""success",
  "gatewayList": [
      "ip""string",
      "devName""string",
      "intfName""string"
statusCode
integer
Code issued by NetBrain server indicating the execution result.
statusDescription
string
The explanation of the status code.
