This function returns a list of files contained in a specified folder.
Resource Information
Method
URL
Required authentication
POST
/V1/CMDB/Files/
Yes
Parameters
Name
Description
Token*required
(header)
The token can be obtained by sending a POST request to the log in session endpoint and provide valid credentials.
Body*required
(body)
The body contains the following parameters:
folderid (string): The ID of the folder from which you want to get the files. Return the root folder (Public) if folderid is null.
fileTypes*(array): the file types you want to retrieve. There are three file types:
0: Folder
11: Map
21: Dashboard
Example:
"folderId""",
"fileTypes": [ 011 ,21]
Response
Parameter
Type
Description
Example
items
array
A list of folders and files.
    "items": [
            "originalId":"75ff3cdf-dff4-48c6-a736-7a86e4374a29",
            "id":"ad09aa07-b31d-4f42-a0aa-319697825b09",
            "name":"Public/Site Maps",
            "type":0
            "id":"2a19165f-a4a5-4488-ac5d-acdf9e287ed6",
            "name":"Public/New Folder/New Folder/New Map",
            "type":11
            "originalId":"d2650deb-5276-44cb-be21-43e2b129380a",
            "id":"a84cdca3-3710-47b1-b037-665e38fd6d08",
            "name":"Public/New Folder(1)/New Map",
            "type":11
    "statusCode":790200,
    "statusDescription":"Success."
id
string
The ID of a folder in the file tree.
name
string
The name of a file.
originalId
string
The ID of a specific dashboard or file.
(Used for Map or Dashboard type only.)
type
integer
The type of a file.
0: Folder
11: Map
21: Dashboard
