This function returns a list of accessible domains in a specific tenant. The returned accessible domains vary by the user privileges you use to log in. To retrieve a full list of domains in a specified tenant, you must log in with system admin or tenant admin permissions.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Domains |
Yes |
Name |
Token*required |
The token can be obtained by sending a POST request to the log in session endpoint and provide valid credentials. |
tenantId |
Unique identifier for the tenant from which you desire to retrieve the domain information. tenantId can be retrieved from get all accessible tenants. |
Parameter |
Type |
Example |
domains |
array |
A list of all accessible domains. |
domainId |
string |
The domain ID. |
domainName |
string |
The domain name. |
statusCode |
integer |
Code issued by NetBrain server indicating the execution result. |
statusDescription |
string |
