Gapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Gapp files.
Working with Gapp Center
1.Click the start menu and select Gapp Center. The Gapp Center pane contains the following three categories by default:
Built-in Gapps contains the pre-installed Gapps. This category is accessible to all users but can only be modified by system administrators.
Shared Gapps in Tenant — contains Gapps that are accessible to all users in this tenant.
My Gapps — contains Gapps that are only accessible to yourself. You can find your private Gapps in all accessible domains under one tenant.
2.Point to a Gapp file and click the icon to preview it.
Further operations:
Creating a Folder in Gapp Center
Importing Gapps into Qapp Center
Exporting a Gapp from Gapp Center
Saving a Gapp to Another Destination
