Variable mapping relationships can only be individually exported per parsers.
1.Click the start menu and select Variable Mapping.
2.In the Variable Mapping page, select a Qapp or a parser that you want to export mapping relationships for.
Tip: To filter your interested device types in the exported file, click Device Types in Network to narrow down.
3.Click Export.
Tip: When you export a Qapp file, the variable mappings for its referenced parsers will be included as well.
