The system returns an API status code for each API call, which conveys the results of an API request.
The following table lists the status code for API calls.
Service Status Code |
HTTP Status Code |
Success |
790200 |
200 |
Success. |
790201 |
201 |
Created (the result of POST method). |
Parameter Validation Failure |
791000 |
400 |
Null parameter. |
791001 |
400 |
Invalid parameter. |
791002 |
400 |
Invalid value. |
791003 |
400 |
Parameter conflict. |
791004 |
400 |
Invalid tenant. |
791005 |
400 |
Invalid domain. |
791006 |
400 |
Non-existing data. |
791007 |
400 |
Data conflict. |
791008 |
400 |
Unsupported feature. |
791009 |
400 |
Null or invalid value. |
792000 |
400 |
Attribute not editable. |
792002 |
400 |
Attribute not supported. |
792003 |
400 |
Built-in attribute deletion error. |
792004 |
400 |
Field name violation. |
792005 |
400 |
Value out of range. |
792006 |
400 |
Alphabet string constraint. |
792007 |
400 |
Character validation failed. |
792008 |
400 |
Invalid address. |
792009 |
400 |
Invalid type. |
792010 |
400 |
The map is not existing. |
792011 |
400 |
Unknown switch. |
792030 |
400 |
Zero or negative value. |
792031 |
400 |
Negative value. |
792040 |
400 |
Unknown source gateway. |
792100 |
400 |
Site transaction not found. |
792102 |
400 |
Site locked. |
792105 |
400 |
Trying to execute an operation that is invalid for a leaf site. |
792110 |
400 |
Trying to execute an operation that is invalid for a container site. |
Server Exception |
793000 |
500 |
Unexpected Error. |
793001 |
500 |
Inner exception. |
793011 |
500 |
Task error. |
Routing Error |
793404 |
404 |
No routing resource found for given URL. |
793405 |
405 |
The method is not supported for given HTTP request. |
Task or Operation failure |
794000 |
400 |
No IP to discover. |
794001 |
409 |
The task is already in running state. |
794002 |
400 |
Run disabled task. |
794003 |
400 |
Task type is not scanned. |
794004 |
400 |
The task is not existing. |
794005 |
400 |
Failed to start a task. |
794007 |
400 |
incomplete task. |
794008 |
400 |
failed task. |
794009 |
400 |
Canceled task. |
794010 |
409 |
Operation conflict. |
794011 |
400 |
Operation failed. |
794100 |
400 |
Task type error, not a benchmark task. |
794101 |
400 |
Task type error, not a discovery task. |
Authentication Failure and Permission Error |
795000 |
401 |
Authentication error. |
795001 |
403 |
Insufficient permissions on tenant or domain. |
795002 |
403 |
No permission to log into the system. |
795003 |
403 |
Insufficient permissions. |
795004 |
401 |
The session expired. |
795005 |
401 |
Invalid token. |
795006 |
408 |
Request timeout. |
795007 |
402 |
Exceeds tenant available node. |
795008 |
400 |
Do not allow resetting passwords. |
795009 |
400 |
Do not allow modifying parameter. |
795010 |
400 |
The session does not exist. |
795011 |
402 |
API calls exceeded the limit. |
795012 |
402 |
No API license or license expired (could be caused by license check failure). |
External Approval for Change Management |
798800 |
400 |
The change management failed to bind to a ticket. |
798801 |
400 |
The change management was already bound to another ticket. |
798802 |
400 |
The change management is not allowed to bind to a ticket. |
798803 |
400 |
The change management state is not allowed to be changed. |
798804 |
400 |
Failed to update the change management state. |
798805 |
403 |
License missing or invalid. |
