Visualizing and Documenting Your Network
Accurate documentation is critical for maintaining a reliable and secure network. However, 80% of network teams can’t keep the documentation up-to-date because the workflow is manual laboring, tedious, and time-consuming. And what's more, the materials of an enterprise network are often scattered throughout multiple sources.
With NetBrain documentation automation, you can export the following types of documents efficiently with one-click:
Using Maps to Visualize Network (in MS Visio)
Inventory Report (in MS Excel or CSV)
Word Document (in MS Word)
When your live network changes, NetBrain benchmark engine will capture those changes and automatically update the backend data model. Besides, the system can be synchronized with the data from the external CMDBs to serve as a single source of truth for all asset data correlations. This ensures that the inventory information is accurate and comprehensive.
Scheduling Tasks
Single Source of Truth
