Each device has a system built-in image so as to show its main physical appearance in the system. You can add more images in the Device Details pane.
1.In the Device Details pane, click the image at the upper-left corner of the pane. A magnified image will prompt.
2.Click Edit to open the Edit Device Images dialog.
▪To add a new one, click Add Image to select the file and click Open.
Tip: The supported formats of image files are .bmp, .jpg, and .png.
▪To delete it, point to the image and click the
icon to select Delete from the drop-down menu.
Note: You cannot delete the system built-in image of each device or apply it to other devices.
▪To apply the image to other devices, point to the image and click the
icon to select Apply to other devices from the drop-down menu.
▪Opening the Device Details pane
