1.Extend a Basic Output node from the Table node.
2.In the Output node, add two conditions and define it as follows:
Condition1: $ping_result == True
Condition2: $ping_result =! True
3.Output a message when Ping succeeds:
1)Point to the Output node, click the
icon, select Condition1, select Message from the Action Node drop-down list and click Extend.
2)In the Message1 node, set the message level as Information and define the message: Ping successful!
4.Output an alert message when Ping failed:
icon, select Condition2, select Message from the Action Node drop-down list and click Extend.
2)In the Message2 node, set the message as Alert and define the message: Ping failed from $this to 8.8.8.8.
5.Save and run the Qapp.
