If the third-party API server supports python script inputs, you can launch the pre-defined API-triggered diagnosis tasks through the following sample scripts (replace sample parameters with real instances):
import requests
import json
import time
import requests.packages.urllib3 as urllib3
urllib3.disable_warnings()
# Need to install requests package for python
# pip install requests
user = "NetBrain"
pwd = "NetBrain"
host_url = "http(s)://<IP address of NetBrain Web Server>/"
headers = {'Content-Type': 'application/json', 'Accept': 'application/json'}
Get token for netbrain
TENANT = 'BVT_DB2TEN_83880'
DOMAIN = 'zjtest'
def getTokens():
login_api_url = r"/ServicesAPI/API/V1/Session"
Login_url = host_url + login_api_url
data = {
"username": user,
"password": pwd
token = requests.post(Login_url, data=json.dumps(
data), headers=headers, verify=False)
if token.status_code == 200:
print(token.json())
return token.json()["token"]
else:
return "error"
# get token
token = getTokens()
headers["Token"] = token
def get_tenant_domain_id():
tenant_id_url = '/ServicesAPI/API/V1/CMDB/Tenants'
full_url = host_url + tenant_id_url
data = requests.get(full_url,headers=headers,verify=False)
tenant_id = ""
domain_id = ""
if data.status_code == 200:
for tenant in data.json()['tenants']:
if TENANT == tenant['tenantName']:
tenant_id = tenant['tenantId']
if tenant_id:
domain_id_url = '/ServicesAPI/API/V1/CMDB/Domains'
full_domain_url = host_url +domain_id_url
domain_data = requests.get(full_domain_url,params={'tenantId':tenant_id},headers=headers,verify=False)
print(domain_data.json())
if domain_data.status_code == 200:
for domain in domain_data.json()['domains']:
if DOMAIN == domain['domainName']:
domain_id = domain['domainId']
return tenant_id,domain_id
else:
def Logout():
logout_url = "/ServicesAPI/API/logout"
time.sleep(2)
full_url = host_url + logout_url
body = {
"token": token
result = requests.post(full_url, data=json.dumps(
body), headers=headers, verify=False)
print(result.json())
if result.json()["statusCode"] == 0:
print("LogOut success...")
else:
data = "errorCode" + "LogOut API test failed... "
return data
# Trigger API function
def TriggerTask(API_Body):
# Trigger API url
API_URL = r"/ServicesAPI/API/V1/Triggers/Run"
# Trigger API payload
api_full_url = host_url + API_URL
api_result = requests.post(api_full_url, data=json.dumps(
API_Body), headers=headers, verify=False)
if api_result.status_code == 200:
return api_result.json()
else:
def stopTask(taskid):
stop_url = '/ServicesAPI/API/StopTask'
full_url = host_url + stop_url
data = {
'task_id': taskid
api_result = requests.post(full_url, data=json.dumps(
return api_result
if __name__ =="__main__":
# tenant_id,domain_id = get_tenant_domain_id()
# print(tenant_id,domain_id)
tenant_id = 'e8bd5e21-1f76-2e30-086d-5bfa186c144d'
domain_id = '92b19d13-8859-4836-a4fb-ce85f5edf657'
API_BODY = {
'domain_setting':
'tenant_id': tenant_id,
'domain_id': domain_id
'basic_setting':
'user': 'admin',
'device': "BJ*POP",
'stub_name': 'stub4',
# 'stub_name': 'stub1',
'triggered_by':"Netbrain",
# 'intf_name': 'FastEthernet0/0'
# print(get_tenant_domain_id())
# "map_setting":
# "map_create_mode":3,
# "map_path_para":
# "is_live":True,
# "source":"GW2Lab",
# "destination":"172.24.101.22",
# # "source_port":1025,
# # "destination_port":80
# API_BODY = {
# 'domain_setting':
# 'tenant_name': TENANT,
# 'domain_name': DOMAIN
# 'basic_setting':
# 'user': 'admin',
# 'device': "BJ*POP",
# 'stub_name': 'runbook',
# # 'stub_name': 'stub1',
# 'triggered_by':"Netbrain",
# # 'intf_name': 'FastEthernet0/0'
print(TriggerTask(API_BODY))
# body2={
# 'domain_setting':
# 'basic_setting':
# 'user': 'wangzheng',
# 'device': 'MPLS_CE2',
# 'stub_name': r'Ping and TraceRoute'
# 'ping_setting':{
# 'source':"MPLS_PE2",
# "source_interface":"Ethernet0/0",
# "destination":"MPLS_CE1",
# "destination_interface":"FastEthernet0/0",
# 'timeout_seconds':3,
# 'packet_bytes':651,
# 'packet_count':1111
# 'tracert_setting':{
# 'source':'MPLS_CE1',
# 'source_interface':'Ethernet1/0',
# 'destination':"MPLS_CE2",
# 'destination_interface':'Ethernet2/0',
# 'max_hops':30
# print(TriggerTask(body2))
