The following table lists the module properties (case-sensitive).
Property Name |
Display Name in Device Details Pane |
name |
Slot# |
The modules of a device. |
type |
Module Type |
The port counts of a module. |
ports |
Ports |
The module type of a module. |
sn |
Module Serial Number |
The serial number of a module. |
hwrev |
HW Rev |
The hardware revision of a module. |
fwrev |
FW Rev |
The firmware revision of a module. |
swrev |
SW Rev |
The software revision of a module. |
descr |
The description of a module. |
