Each time you export a Word document from a dashboard, you can save it as a dashboard snapshot to collect the documents exported from a dashboard and record the export time. With a dashboard snapshot, you can quickly find the historical network data or network design to analyze network changes or troubleshoot.
To view a dashboard snapshot:
1.In the upper-left corner of a dashboard, click N Dashboard Snapshots.
Tip: If the Create Snapshot link is displayed here, which means no dashboard snapshot is created, you can click the link to create one. See Exporting a Word Document from Dashboard for instructions.
2.In the Snapshot Manager, right-click the target snapshot and select Download. The Word document associated with the snapshot is downloaded.
▪Using Dashboard to Visualize Multi-Dimensional Data
