1.Run the rpm -qa|grep netbrainlicense command to check whether License Agent exists on the server.
[root@localhost ~]# rpm -qa|grep netbrainlicense
netbrainlicense-10.0.10-el.x86_64
2.If exists, complete the following steps to uninstall License Agent:
1)Run the cd /usr/lib/netbrain/installer/licenseagent command to navigate to the licenseagent directory.
2)Run the ./uninstall.sh command under the licenseagent directory.
[root@localhost ~]# cd /usr/lib/netbrain/installer/licenseagent
[root@localhost licenseagent]# ./uninstall.sh
Check service status.
Check result.
Stopping service netbrainlicense.service
Get port number.
Close the port.
Remove the port from firewall.
Preuninstall done.
NetBrain License Agent has been successfully uninstalled.
