1.When a map is opened, click the map name.
2.In the drop-down, you can switch to the copy you would like to view.
Tip: In the drop-down, you can also view each owner's status, i.e., whether they login to the NetBrain system.
3.After switching to the copy, you can also see the Runbook on that copy.
