Solving a problem often requires multi-person cooperation and various data types (such as map, NI, probe, Runbook...). and then solve the problem through troubleshooting and reviewing. Preventive Automation (Adaptive Monitoring) data subscription allows users to see all diagnosis results related to current network problems in the most recent time, which helps to locate and solve problems faster.
The flow of Preventive Automation (Adaptive Monitoring) data subscription is as follows:
▪The flash alert generated by the probe will generate incident messages.
▪The alert status code generated by NI will generate incident messages, which can also be seen in the output of the diagnosis pane.
▪You can choose which probes to subscribe to and which NI/NICs are included in the probe:
▪Specify subscription scope of probe:
oAll Probes of Incident Devices: All probes are subscribed.
oSelected Probes: Select a part of probes.
▪Specify subscription scope of NI/NIC:
oAll NIs of Incident Devices: All the NI/NIC.
oNIs with Tags: You can filter NI based on the NI tag.
oSelected NIs: Select a part of NIs.
▪Define subscription time: Fill in the absolute value of the time. After submission, it is only valid for the future time, and the results generated from the past time will not be synchronized.
