1. You can search for Qapp, Gapp, Runbook Template and Data View Template in the Search bar.
The following table list the properties supported to search for Automation Assets:
Automation Assets |
Search with name |
Search with description |
Search with tag |
Qapp |
Gapp |
Runbook Template (RBT) |
Data View Template (DVT) |
