The system provides the following pre-defined roles, and the default privileges of each role are listed as follows.
Privileges
Explanation
Domain Admin
Power User
Engineer
Guest
Network Change Creator
Network Change Executor
Network Change Approver
Portal Temp User
Domain Management
Log in to the Domain Management page and do the following domain management tasks:
View, export, and delete discovery report in the Fine Tune
Add network definition
View, add, modify, delete, and disable topology links in the Topology Link Manager
Resolve duplicated IPs and subnets in the Duplicated IP and Subnet Manager
Add checkpoint OPSEC tasks in the Checkpoint OPSEC Manager
Configure network security settings and L2/L3 topology building options
Configure a desktop profile for all users under a domain
Share Policy Management
Configure share policy (assign domain access and privileges to other users in this domain)
Device Management
Add, modify, and remove MPLS cloud
Remove devices from a domain
Shared Resource and File Management
Only system/tenant administrator can edit built-in files in the shared folder of Device Group, Qapp, Gapp, Parser, Dashboard Widget and Template, and Runbook Template
Site Management
Add MPLS clouds and unclassified network devices from the Fine Tune to a site
Open the Site Manager to do site management, such as creating, editing, deleting, importing, committing, and rebuilding sites
Discover/Tune Network Device
Create a do-not-scan list
Add discovery tasks from the Start Page or the Schedule Task page
Rediscover selected IPs and devices in the Fine Tune
Tune live access
Run on-demand discoveries
Schedule Benchmark
Add benchmark tasks from the Start Page or the Schedule Task page
Manage Network Settings
Configure and manage shared network settings
Manage Device Settings
Configure and manage shared device settings for each device in a domain from the following entries:
Site pane
Map
Fine Tune
Discover
Tune Live Access
Access to Live Network
Retrieve live device data from the network, which includes:
Run CLI commands and Qapps on a map page or in a runbook
Run monitor (Qapp-based) widgets and retrieve live data in static widgets in a dashboard
Retrieve variables once or monitor variables periodically from the live network in Instant Qapp
Calculate live paths (use the live network as the data source)
Browse live access logs
Create Network Change
Create network change tasks
Execute Network Change
Execute network change tasks
Approve Network Change
Approve network change tasks
View Network Change
View network change tasks
Map Layout Management
Associate layout styles with site maps and shared device group maps
Variable Mapping Management
View and manage variable mappings
Run Qapp
Run and schedule Qapp tasks
Golden Baseline Manual Definition
Define golden baseline manually
Golden Baseline Dynamic Calculation Management
Enable or disable dynamic calculation to set golden baseline
Manage SPOG URL
View and define SPOG URL
Portal Management
Manage function portals
Private Resource Management
Manage private resources including:
Qapp
Gapp
Parser
Data View Template
Primary Probe Management
Create, read, update, and delete Primary Probes
Secondary and External Probe Management
Create, read, update, and delete Secondary and External Probes
Adaptive Monitoring Polling Control
Manage Adaptive Monitoring Polling including:
Adjust polling frequency
Configure blocking time
Configure polling delay
Triggered Intent Management
Install Triggered Intent
Edit Execution Tree
Schedule CLI Command
Add Schedule CLI Commands
Run Ansible Task
Execute Ansible Task node in Network Change (CM) and Runbook
