You can save frequently used network changes tasks as templates so that you can quickly create other network change tasks based on the predefined templates.
To browse network change templates in your domain:
1.Click Network Change in the taskbar.
2.In the Network Change Manager, click Network Change Templates. The system provides the following three categories of change templates:
▪Built-in Templates — contain the pre-installed change templates. This category is accessible to all users but can only be modified by system and tenant administrators.
▪Shared Templates — contain the change templates that are accessible to all users in this domain.
▪My Templates — contain the change templates that are only accessible to yourself in this domain.
3.To quickly find your interested change template, use the one or a combination of the following filters:
▪Device Types — filter network change templates by specified device type (only if it has been defined in the Start node of a network change template).
▪Authors — filter network change templates by specified author name.
▪Tags — filter network change templates by specified tag (only if it has been defined in the Start node of a network change template).
1.Create a network change task.
2.In the Network Change Template editor, click the
icon and select Save as Network Change Template.
3.Click Save, select a location in the pop-up dialog, enter a name and click OK.
