The table below describes the SDN (including SD-WAN) device types and vendors supported in the system:
Technology |
Device Type |
Supported Level |
Discovered via |
Tier 1 |
Tier 2 |
Tier 3 |
SDN-WAN |
CloudGenix ION SD-WAN |
CLI/API |
VeloCloud Edge |
SNMP/CLI |
VeloCloud Gateway |
SNMP/CLI |
VeloCloud Orchestrator |
SNMP |
Versa Analytics |
CLI |
Versa Controller |
API |
Versa Director |
CLI |
Versa FlexVNF |
API |
Viptela vBond |
API |
Viptela vEdge |
SNMP/CLI |
Viptela vManage |
API |
Viptela vSmart |
API |
Cisco Meraki Z3 |
API |
Cisco MX |
API |
Aryaka router |
SNMP |
Cisco ACI |
Cisco ACI APIC |
API |
Cisco ACI Leaf Switch |
API |
Cisco ACI Spine Switch |
API |
EXSi |
VM Host |
API |
vSphere Distributed Switch |
API |
vSphere Standard Switch |
API |
VM NSX-V (for vSphere) |
NSX Manager |
API |
NSX Controller |
API |
NSX Logical Switch |
API |
NSX Edge Security Gateway |
API |
NSX Distributed Logical Router |
API |
AVI |
AVI Controller |
API |
AVI Service Engine |
API |
Big Switch |
Big Switch Controller |
SNMP/CLI/API |
Big Switch Spine Switch |
API |
Big Switch Leaf Switch |
API |
The limitations on SDN support include:
▪Cisco ACI
oRemote Leaf is not supported.
oCannot map out EoMPLS devices between Transit Leaf and Spine for Stretched Fabric deployment that uses EoMPLS to interconnect Transit Leaf and Spine.
oRunning Qapps on logic nodes (like Tenant, VRF, EPG, etc.) are not supported.
▪NSX-V
oOverlay L2 topology and underlay paths are not supported.
▪Big Switch
oOnly can get spine/leaf switches' L2 link(NDP) table, other data is retrieved from controller as NCT tables.
▪Cisco Meraki Z3 and MX
oSD-WAN routing table is populated by NetBrain’s algorithm, but not exported by API.
o The netmask of some interfaces couldn’t be accurately retrieved by API. However, the netmask of the VLAN interface could be retrieved by API.
