More Built-in Data and Functions to Support IPv6
More Built-in Data to Support IPv6
The following built-in data have been added to the NetBrain platform to facilitate the subsequent data analysis and better support the IPv6 related functionalities:
Data Table
Description
Improved Status
1
Route Table
Add a new NCT table: IPv6 Route Table.
Only support data retrieval via CLI
2
CDP Table
Add two more columns to the existing CDP table to retrieve the Global IPv6 Address and Link Local Address
3
Neighbor Discover Table
Provide a separate IPv6 neighbor table for IPv6; the columns resolved by NCT are Type, IPv6 Global Address, MAC address, Interface, Vlan, Private Vlan, Age, State, and Time Left.
4
Interface Information
Add the additional command of the IPv6 interface to analyze the IPv6 interface-related information when parsing the config file.
More Functions Supporting IPv6
1.Share/Private Device Settings: the device management IP supports IPv4 and IPv6.
2.Change Management Login Settings now supports IPv4 and IPv6.
3.Batch Tune: the management IP in both Tune Live Access Settings and Tune Private CLI Settings now supports IPv4 and IPv6. In addition, the management IP in the UI supports the display of IPv4/IPv6 address format.
4.Fine Tune: the following functions of Fine Tune also support the IPv6 address format.
Function
Description
1
Unknown IP
Unknown IP supports IPv6 address format.
2
Discovered Device
Management IP supports IPv6 address format.
3
Missed Devices
4
Discovered by SNMP
5
Unknow SNMP SysObjectID
6
Unclassified Network Devices
