Member Network Intent Execution
NIC defines the logic to check the network state against the Intent and create a map for the Intent. You can specify which to execute.
1.Select the Execution mode:
Execute Network Intent Only: The Diagnosis will be available for the manual Trigger NetBrain Diagnosis (in the Integrated IT system and Incident Portal)
Insert Intent Map Only: The Diagnosis will be available for the manual Trigger NetBrain Map (in the Integrated IT system and Incident Portal).
Execute Network Intent and Add Intent Map.
2.Select the Network Intent Setting: defining how the results are displayed in the Incident Portal.
oSet Incident Device after Execution: You can set the incident device(s) to include all Network Intent devices or only the Network Intent Devices with the alert status codes.
oCreate Incident Message by Status Code: This will create an Incident message with the status code.
If an NI has an Intent Map, the system will display the map in Incident Portal. Otherwise, the system will create an Intent Map according to the logic defined in NIC. An incident message will also be created with a hyperlink of the Intent Map.
