1.Click and select Intent-Based Triggered Automation.
2.Click the Static Diagnosis tag to view all diagnoses.
3.Select a diagnosis, click .
You can:
• Edit, Delete and Test the diagnosis.
• Export the diagnosis to a local file.
• Duplicate the diagnosis, which will create an identical new diagnosis.
oTo export all diagnoses, click .
oTo import diagnosis from a file: click> click Import Static Diagnosis … > select a local file in the pop-up window.
