1.In your web browser, navigate to http(s)://<Hostname or IP address of NetBrain Web Server>/. For example, https://10.10.3.141/ or http://10.10.3.141/.
2.In the login page, enter your username or email address, and password.
Note: If you are using SSO (Single Sign-On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified.You will directly log in to the system and you can skip step 3.
Tip: To go to the administrator login page, click Administrator Login.
3.Click Log In.
Note: It is not recommended to use the same web browser to log in to the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
4. Please change the initial password if it is your first-time login.
