To invite colleagues focusing on the same task to access an incident, you can either share the Incident URL with NetBrain IE users and/or external users, or directly invite the users with IE accounts to the incident.
Invited users will become members of the incident as soon as they accept the invitation and join the incident, enabling them share the same information.
1.Navigate to the Members tab of the created incident.
2.Click Invite User.
3.Enter a username and then select the matched user account from the populated drop-down list, or directly enter an email address.
4.Click Invite.
You need to obtain the incident URL and access code to invite users without IE seat licenses to be members of an incident.
1.On the Members tab, define the following information.
1)Select the Enable Incident Portal check box, which allows external users can access an incident with necessary information.
2)Set access code for external users. Enter a code and click the
icon to confirm it.
3)Click Copy Invitation, and the detailed information is displayed. Click Copy to Clipboard.
2.Share the incident portal's information with external users via email or instant messaging tools.
3.External users can access the incident portal with shared information.
Note: See Incident Portal for more details.
Tip: You can also invite external users in the Edit Incident dialog or the Advanced Settings dialog.
