Front Server is a key component of NetBrain system to manage the following tasks:
▪Collect network data, such as route tables, ARP tables, NDP tables, configuration files, and other data from your live network.
▪Provide proxy service for Ping, Telnet, SSH, and other live tools.
Each Front Server is recommended to manage 5,000 network nodes at most. Depending on your network scale, you can deploy either a standalone Front Server, or multiple Front Servers for load balancing.
Note: Ports 7778, 7086, and 29916 must be open for internal communications.
Select either of the following ways to install Front Server, depending on your operating system:
▪Installing Front Server on Linux
▪Installing Front Server on Windows
