The following data types for each device can be exported from the Device Details pane:
Device/interface/module properties
Configuration file
Data tables
CLI commands
Batch Exporting Data from Device Details Pane
1.In the Device Details pane, click Export.
2.Select the data types that you want to export, and click Export.
3.Click the Device Data hyperlink to download data.
You can open the downloaded file directly. The default file location is C:\Users\<your username>\Downloads.
Tip: The configuration file is exported in .config format, the CLI command outputs are exported in .txt format, the data tables and device/interface/module properties are exported in .csv format.
Exporting a Single Data Type from Device Details Pane
Take exporting a global ARP table for example:
1.In the Device Details pane, click Data Tables > ARP.
2.Click the icon to pop out the ARP table in a pop-up dialog.
3.To find the ARP table retrieved in a specific baseline, specify the data source and execution time. See Data Source for more details.
4.Click the icon to export the ARP table of the device into a .csv file. The default file location is C:\Users\<your username>\Downloads.
Opening the Device Details Pane
