The following actions will trigger the NetBrain system to send emails or NetBrain Workstation notifications to the relevant users.
Action |
Email/NetBrain Workstation Notification Receiver |
Invite |
The user who is invited Note: The invited user will receive the email even if the email notification function has not been enabled. |
The user who is mentioned Note: The mentioned user will receive the email even if the email notification function has not been enabled. |
Join/leave incident |
Incident members |
Remove user |
Incident members |
Close/open incident |
Incident members |
Add/remove map |
Incident members |
Whether to send email notifications to incident members is also configurable in the Incident Advanced Settings.
Note: The profile users of the incident portal will receive emails in the above situations no matter whether the email notification function is enabled or not.
