In this version, the discovery functionalities have been improved to support the discovery of single-stack IPv6 devices, including:
▪Discovery via Seed Routers: supports the input of both pure IPv6 addresses and a mix of IPv4/IPv6 addresses
Note: This IEv10.1 does not support the neighbor walking of IPv6 address discovery.
▪Scan IP Range: supports the input of both single IPv6 address and range of IPv6 address.
Note: The IPv6 network segment must be specified by the mask, and the mask must be less than or equal to the 104-bit mask).
Other discovery related information on IPv6 support includes:
1.Support IPv6 Address in Do Not Scan Definition:
▪Supports entering both IPv4 and IPv6 subnets into a Do not scan list when defining Do Not Scan based on Subnet.
▪The input IP address format (IPv4 or IPv6) can be automatically identified.
▪The input subnet mask range supports dynamic change.
2.Support IPv6 Address in Network Definition: Network Definition allows users to manually define the device type and driver used by an IP address range when the device type and driver device cannot be accurately identified through SNMP. The definition of IPv6 is supported in the IP address range, which is consistent with the IP range specs in Discovery.
3.Advanced Options for Discovery: Some Advanced Options (neighbor walking) do not support IPv6.
4.Import IP List Template: a download template file menu and a template file are provided for user reference.
