The main flow of discovering Cisco ACI networks are as follows:
▪Set Up APIC Server Access for NetBrain — double-check the configurations on your APIC server where you can read data from.
▪Discover ACI Data in NetBrain Domain — discover the network data model (Single Site or Multi Site) in a NetBrain domain.
▪Auto-Update ACI Data in NetBrain through Benchmark — execute a benchmark task to retrieve all data and build all components, including visual spaces and data views.
