The operating system must be installed with an English-language version (not language packs).
When installing NetBrain servers, comply with your company security policy to set the passwords and archive them for further reference.
NetBrain servers use hostnames to identify and communicate with each other. Make sure each server has a unique hostname.
Add all the NetBrain installation folders and files (on both Windows and Linux) to the allow list of antivirus software for routine scans, and keep the TCP connections unblocked between NetBrain components.
If the machine's firewall is turned on, make sure the firewall rules allow traffics to all the ports and protocols that will be used by the NetBrain system.
The Service Monitor Agent running on the Linux server(s) uses “netbrainadmin” user, and this user needs sudoers privilege to monitor other NetBrain components as well as to execute the system update tasks.
Special Requirements for Client Machine
Special Requirements for Windows Server
Special Requirements for Linux Server
Supported Web Browsers
Third-Party Dependencies
