Defining Feature Intent Template
1.Click ,scroll down and select Feature Intent Template.
2.In Feature Intent Template Manager page, hover over the desired folder.
3.Click on , and select New Feature Intent Template.
4.Define the Feature Intent Template in the Define Template Tab.
    A Feature Intent Templates typically consists of the following components:
Device Matching Logic
Automation resources to be created
Automation resources execution
5.Click Save after defining the Feature Intent Template.
Tip: You can follow the steps below to define Network Intent directly with analysis logic in FIT YAML:
1)Define the analysis logic in the analysis_device section of the network intent YAML.
2)Import the visual parser and reference it in the YAML file.
