By default, devices on each map page are displayed in the default data view.
Tip: To update default data view with the latest data saved in the database, you can configure through a scheduled benchmark task. See Updating Default Data View for more details.
Default Data Units on Device Positions
The following table lists the default data units in each device position.
Position
Device Data Unit
Position1
Management IP
Position2
NULL
Position3
NULL
Position4
NULL
Note: If the value of a data unit is null, it will not be displayed in the specified position.
Default Data Units on Interface Positions
The following table lists the default data units on each interface position for different topology types.
Position
Interface Data Unit
IPv4 L3 Topology
(IP Interface)
IPv4 L3 Topology
(Device Interface)
IPv6 L3 Topology
(IP Interface)
L2 Topology
Position1
Routing Protocol
Unnumbered IP
Link-local
Mode
Position2
NULL
Routing Protocol
IPv6 Routing Protocol
Trunk Encapsulation
Position3
Multicasting Mode
Multicasting Mode
Multicasting Mode
Speed
Position4
MPLS VRF
MPLS VRF
MPLS VRF
Duplex
Position5
Inbound ACL
Inbound ACL
Inbound ACL
Access Vlan
Position6
Outbound ACL
Outbound ACL
Outbound ACL
Native Vlan
Position7
Description
Description
Description
Description
Position8
NULL
NULL
NULL
NULL
