With Auto-Refresh enabled, any changes made on the map will be automatically synchronized to the current view-only map. Then users can view the latest version of the map.
Note: Auto-refresh is only available to the maps not owned by you, i.e., you don't have editing rights to the map.
1.Open a map you don't have editing rights to, the map will be in View-Only mode.
2.Enable Auto Refresh.
only.png)
3.Click
and configure Refresh Settings.
▪ Refresh All (Map & Data View)
This option means reloading the latest saved map first and then reapplying the data view last selected in the map when refreshed.
▪Only Refresh Data View
This option means reapplying the data view currently selected in the map when refreshed.
Example: If the map owner drags and moves devices on a map to change the map layout or zoom in/out the map, the view-only map layout remains unchanged when refreshed.
