API Server Manager is used to define the required parameters for API Adapters to interact with API servers, such as endpoints and credentials for an API adapter to access your third-party system.
Note: Each API server can only associate with one API adapter. But within one tenant, each API adapter can be associated with multiple API servers.
2.In the Domain Management page, click the
icon in the upper-left corner of the page and select API Server Manager.
3.On the API Server Manager tab, click Add.
4.Enter the server name and the description.
5.In the API Source Type field, select the API adapter.
6.In the Endpoint field, enter the third-party API service address.
7.Enter the username and password to access the third-party API server.
8.Select a Front Server, and click Test to check the connection.
9.Click OK.
Tip: You can export the full data of either all the devices or only the interested devices (by using search function) managed by each API server.
