The system centralizes the scattered description and annotation functions (such as the description of Runbook or a Runbook node) in a single pane as follows, including Runbook tags, category, author, modified time, annotation, and device qualification readiness for each node.
The centralized document pane is also available in Runbook Template when you:
▪Edit a Runbook Template Document:
